how hard to do rear archs.
Old Jun 6, 2008 | 10:47 PM
borderfox's Avatar
borderfox
Default how hard to do rear archs.
as above. a mate of mine wants me to do a mini resto on his rs but both arch's are rusting behind the trim. i mean as you look side on just on the upper middle is rough.. much in to this job..
chears
Old Jun 6, 2008 | 11:10 PM
nickscunny's Avatar
nickscunny
my 1996 rs2000 rear arch is fubared...... i want to do it myself, i can weld....
but my mate reckons its a job for a pro because theres a chance the heat can warp the whole rear quarter......
Old Jun 6, 2008 | 11:17 PM
daz1968's Avatar
daz1968
I would say if you are confident at welding there should not be a problem, buy a tool for joggling the edges to help with keeping them flush, cut out all bad metal on inner and outer arches and if only a little area just cut the new panel down to replace what is required and you should have no problems at all. I did this on a Fiesta turbo a few years ago and even managed to keep the paint damage to the area that will be covered by the bodykit so did not have to have any professional painting done at all. A light skim of filler over the joint was all that was required, dont worry about distortion just weld small areas at a time until they become a continuous weld, then sand then off till flush.
Old Jun 7, 2008 | 11:54 AM
B1G_RST's Avatar
B1G_RST
leave it for a body shop, its what they do at the end of the day, may be expensive nbut wel worth it,
Old Jun 7, 2008 | 12:06 PM
Cozziekid's Avatar
Cozziekid
What he said
I did mine myself and its not a bad job really, just take your time and triple check all measurements etc before attacking it with a grinder!
Old Jun 7, 2008 | 08:22 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
do the welding is tiny bits (like chocolate chips- and bit here, bit there, bit there etc etc) to really avoid chances of warping
if i did it i'd get a panel, vibro cut the rear to match then weld flat and then the paint crap
if you aint got cool stuff like vibro cutters then jogglers the next best way i spose
beware the inner arch, it could be just as bad
Old Jun 11, 2008 | 07:47 PM
borderfox's Avatar
borderfox
cheers folk foe the advice. i done a small bit of work like this before so i should be ok.
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
cossirob
Sep 3, 2015 09:17 PM
