coolant coming out the exhaust!
Old Jun 6, 2008 | 11:53 AM
the original's Avatar
the original
Default coolant coming out the exhaust!
anyone ever had this on a cossie. quite a lot of coolant spraying out the back of the turbo. (turbo water cooling not connected)
took the head off and can't see any cracks anywhere in block or head. gasket not visibly gone.
are there any common places I should be looking at?
cheers
Old Jun 6, 2008 | 03:08 PM
Nash's Avatar
Nash
Cake lover!
Up up
Old Jun 6, 2008 | 03:17 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
No. 3 or No.2 bore, exhaust side of barrel - hairline crack(s)?
Old Jun 6, 2008 | 03:48 PM
the original
cheers will take another look one day
Old Jun 6, 2008 | 04:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
cheers
you sure it's coolant?
because if it is, your cars broken
and if it's broken, you want it to be doing just a head gasket, and you don't want to be running it at all or else you might find you get hydrostatic lock, which bends your engine even worse
Old Jun 6, 2008 | 04:41 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
11 oclock number 3 bore is prone to crack on a 205 block
Old Jun 6, 2008 | 06:59 PM
the original
thanks. It's actually a 202 block. couldn't see any cracks, just completely vertical scratches I thought off the pistons.
Is the '11 O'clock' looking down into the bore from in front of the car?
yes it's coolant. don't worry I know my car's broken. It won't go back together until I find the fault but I can't find the fault yet..
CossieRich
30
Sep 8, 2015 10:08 PM
muffster
Aug 17, 2015 08:17 PM
RsS2daz
Aug 14, 2015 05:26 AM
Dazts1
Was It You?
Aug 2, 2015 06:44 PM
