cooper rings?
Jun 6, 2008 | 09:42 AM
cooper rings?
im buying a 200 block and the guy im buying ot from said it has cut outs for cooper rings?? what are cooper rings
Jun 6, 2008 | 09:44 AM
Brass (I think) reinforcing rings inserted in a cutout around each cylinder, on the face of the block. Essentially it's an early method of improving cylinder head gasket resilience.
Jun 6, 2008 | 09:50 AM
so its a benefit.. no downside to them?
Jun 6, 2008 | 09:58 AM
Walk away, you will have to have these machined off, which will affect the deck height - find another.
Jun 6, 2008 | 10:02 AM
fuck
mike you know of one anywhere?
iv got a head now. well in the process.
Quote:
Originally Posted by
Mike Rainbird
why will he have to have them machined off, cant you just fit new rings as my block is wire rung wich i believe is a similar thing and i just replaced the wire ?
Jun 6, 2008 | 10:07 AM
I personally wouldn't want to do this on a high power engine, but yes,
you can do anything
you like
However, at this stage he is in a position to chose the best way and not compromise, so I would always recommend the best course of action for the long term.
Jun 6, 2008 | 10:09 AM
i want the best.. not some shit that will fuck up in a year or so..
so mike you know of a block
Jun 6, 2008 | 10:12 AM
Ł1450 brand new in the box with the fitting kit
Jun 6, 2008 | 10:13 AM
is that a 200 block mike?
Jun 6, 2008 | 10:21 AM
No, it's a 205 block that I built up to look like a brand new 200 block with tin foil and paint
Jun 6, 2008 | 10:25 AM
Bargain then
What does the fitting kit have Mike?
Jun 6, 2008 | 10:26 AM
Mike Rainbird
ahhh in that case i dont want it
tell me more mike..what actully comes with it..
need to get this engine built asap.
Jun 6, 2008 | 10:37 AM
The whole shooting match as you would buy from Cosworth - funny that considering where it came from
Fitting kit = baffle plate, ball bearing for the oil gallery behind the flywheel and three core plugs.
Jun 6, 2008 | 10:38 AM
Mike Rainbird
and how long will it take your sarcastic arse to get one
Jun 6, 2008 | 10:41 AM
It's available now. It can be sent to Martin with your head to save on carriage
Jun 6, 2008 | 10:43 AM
ahhh very nice mike.
you have pm
Jun 6, 2008 | 10:44 AM
R5FORD
you have pm
No I don't
Jun 6, 2008 | 10:47 AM
Mike Rainbird
No I don't
yes you do
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
