can someone do me a small welding + drilling job! kent area.
hi guys, just need my flange to be drilled out to a 19mm hole and then this pipe welded onto the flange, i can post the item to you with some cash for the job
regards
p.s i am located in bromley, kent
regards
Send a PM to Fiescos Dan:
https://passionford.com/forum/members/1950-fiecos-dan.html
PS: He's in Kent too.
Yeh but this has the potential to be even shitter!!!
What about this...
http://cgi.ebay.co.uk/_Car-Parts-Acc...3286.m20.l1116
What about this...
What about this...
What about this...
But whats going to happen to your fluro-lined hose once it gets 80psi or more of oil pressure through it? It will pop off and the entire contents of your sump will be spewed all over the engine bay and road.
Best case - It will make a mess.
Worst case - It will catch fire and the oil on the road will cause a motorcyclist to come off and go under a lorry.
Ever the optimist, me.
There are lots of kits on Ebay, infact I have a brand new one here that I haven't used, where you get a nice machined Alloy flange and a proper fitting. Would save ALL the agro.
lee- yes proper fittings on the end, not the most flexible hose though! here is my setup, just want to change the flange and heatwrap the downpipe-
The clearance around the bearings is very small so it only lets a relativley small amount of oil flow past. This combined with a much larger bore exit hose than entrance hose means you will see hardly any pressure in the return.
Hi Rob,
yeah it can be welded with out problem, as long as prep correctly and welded from the plate side.
As Garage 19 said, there is no pressure except crankcase pressure, so will work fine as long as heat wrapped to stop any damage to the hose from the turbo and down pipe.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
