oil light switch
Old Jun 4, 2008 | 05:02 PM
Mark RS's Avatar
Mark RS
Default oil light switch
hi all, i have a series 2 with a high pressure oil pump and the oil light only works for a couple of times and then stops working, but as soon as you earth the wire it brings the oil light on.Do i need a high pressue oil light switch if so were can i get one from.
Old Jun 5, 2008 | 09:23 PM
Mark RS's Avatar
Mark RS
Old Jun 5, 2008 | 09:42 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Huh? The oil light comes on when the pressure is low, so in reality you shouldn't really ever see it once the engine is running.
Old Jun 6, 2008 | 12:40 AM
Micky's Avatar
Micky
As Christian says,if you have good proper oil pressure you should never see the oil light on.The oil light will only come on when you have low pressure (about 7 psi),and if the oil light comes on with the engine running its too late,as the damage will be done already!!!Regards,Micky
Old Jun 6, 2008 | 03:22 PM
adduk's Avatar
adduk
iv got a problem like this,had 2.0 zvh turbo built and when i first started it the oil light was on then after running it ive never seen it on even when starting from cold,do you think pressure switch is faulty or is it just holding pressure well,the bulb works iv earthed the wire and i comes on.cheers oh and sorry for taking over the thread.
xrmalin
Sep 13, 2015 06:52 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
