will a series 2 gearbox fit a series 1
Old Jun 3, 2008 | 01:33 PM
grayzo's Avatar
grayzo
grayzo
Default will a series 2 gearbox fit a series 1
will a series 2 gearbox fit a series 1 rs turbo
Old Jun 3, 2008 | 01:35 PM
Luca's Avatar
Luca
Lukesville
the mounts will need to be swapped
Old Jun 3, 2008 | 01:38 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
yes it will fit but the mounts are entirley different.
why do u need to ask? correct me if im wrong but not many s2 boxes have the lsd as standard either
i had a spare box from an mk3 xr3, which i gave to my mate to put in his S1 that was nearly 3 years ago, and its still going strong!
you best bet is to find a mk3, unless ur competent to make up a bracket!
Old Jun 3, 2008 | 01:56 PM
grayzo's Avatar
grayzo
grayzo
im not competent top do much to be honest lol
il try and find one
Old Jun 3, 2008 | 02:08 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
i got the one for my mate from a scrappy £40 i think?
Old Jun 3, 2008 | 03:34 PM
antony215's Avatar
antony215
Escort Rs Turbo
All S2 have LSD's as standard
Old Jun 3, 2008 | 03:41 PM
addiction's Avatar
addiction
An S1 box will go in an S2 but the S2 box will not go in an S1 because the casing is different where the mounts go!!
all S2's came with an LSD as standard!!
Old Jun 3, 2008 | 03:54 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
there you go!
Old Jun 3, 2008 | 04:47 PM
sm's Avatar
sm
correctamundo the easiest way to do it if u have a s2 box and a fucked s1 box is to swap everything out of the s2 box into the s1 casing
Old Jun 3, 2008 | 05:44 PM
nigel b's Avatar
nigel b
swap the end casing over between the 2
Oct 9, 2015 07:38 PM
Chas
Sep 21, 2015 08:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
RIB1122
Aug 13, 2015 09:09 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
