st24 brakes
Old Jun 1, 2008 | 11:27 PM
stbaz's Avatar
stbaz
Question st24 brakes
will mondeo st24 front brake set up fit on my rs turbo?
Old Jun 2, 2008 | 05:44 AM
anodised's Avatar
anodised
i would think so same as the 4x4 cossy set up i think
Old Jun 2, 2008 | 06:22 AM
bluescortcossie's Avatar
bluescortcossie
the calipers will fit but you would need to use them with 2wd discs and also drill out the 2 bolt holes where the caliper bolts to M12 as they use bigger bolts than the 4wd cossie items but other than that they are the same
not sure if the discs could also be used but i doubt it , would like to know for definite though as they a lot cheaper than 2wd cossie discs !
Old Jun 2, 2008 | 06:25 AM
stbaz's Avatar
stbaz
not sure if the discs could also be used but i doubt it , would like to know for definite though as they a lot cheaper than 2wd cossie discs ![/QUOTE]
i got the lot off ebay for 40 quid! discs, pads, callipers and carriers
Old Jun 2, 2008 | 06:36 AM
bluescortcossie
Ive got mondy calipers on my 3i using 2wd discs
got them from a scrappy for Ł10 but like a tit i forgot to accidentally put the discs in my tool bag so i could try if they fit
keep us posted whether the discs fit or not
Old Jun 2, 2008 | 05:51 PM
stbaz's Avatar
stbaz
yeh i will let you know as soon as i have tried them mate
Old Jun 2, 2008 | 08:49 PM
fonfe's Avatar
fonfe
i use a full st24 setup on my mk4, discs, pads, caliper and carriers so yes they do fit. you need to drill the hub bolt holes out 1 or 2mm for the bolts to fit though and get some spacers made up from stainless steel so the carrier sits central over the discs or if your feeling cheap large ewashers will do just as good a job as spacers.
so all in all st24 discs DO FIT
Old Jun 3, 2008 | 11:42 PM
stbaz's Avatar
stbaz
superb.....thanks
Old Jun 4, 2008 | 10:24 PM
fonfe's Avatar
fonfe
glad to be of help fella, but remember there are two different pads that can go in st24 caliper/carriers so make sure you get the same shape ones as what is meant to be on there!
Old Jun 6, 2008 | 07:44 PM
stbaz's Avatar
stbaz
As Said Before, They Do Fit......fitted Them Tonight.... St24 Discs, Pads And Carriers Using Mk3 Flexi Hoses. Spot On
Old Jun 6, 2008 | 08:06 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
do they fit under std wheels?
Old Jun 6, 2008 | 08:24 PM
stbaz's Avatar
stbaz
no idea mate. ive got 17s on mine, sure ive seen an st24 on 15s before though
Old Jun 7, 2008 | 01:27 PM
fonfe's Avatar
fonfe
yeah they do as when i fitted mine my mate at work wanted to know if they would fit under his wheels as he was thinking about getting some so we put one of his RST wheels on my car and its close, but they do fit. worst case you can shave the caliper a tiny bit as a few people have done this when fitting them to ZS fiestas but with standard RST wheels you shouldnt have any problems.
Old Jun 7, 2008 | 02:47 PM
jonnyrsturbo
sweet cheers
Old Jun 7, 2008 | 03:25 PM
Gadget's Avatar
Gadget
Spanner monkey
yes they fit under standard rims without shaving the caliper and you'll need a spacer of 12mm to use the complete setup, hope that helps!
Old Jun 7, 2008 | 09:28 PM
jonnyrsturbo
what size disc are they as i have cossy brakes (2wd disc 4x4 caliper) on at the mo, but calipers getting abit old now!
are the st24 better?
Old Jun 7, 2008 | 10:15 PM
anodised's Avatar
anodised
tbh i think the st24 are the same as the cossy 4x4
Old Jun 7, 2008 | 11:53 PM
bluescortcossie
they are the same apart from bigger bolts used (M12)
Old Jun 8, 2008 | 08:30 PM
anodised's Avatar
anodised
dont the cossy use m12 aswell i think mine do
Old Jun 9, 2008 | 07:14 PM
fonfe's Avatar
fonfe
easist way to find out any info on brake dics thickness ect is to call up a local motorfactors and ask them as they should have all the right detailson their computers. or look it up on autodata
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
