ECU's, KONI's, LOOM, CHIP etc
Will be taking these parts to sell at Classic Ford show tomorrow (santa pod).
1 x L6 ECU without chip. In good working order taken from my 2WD sapphire i stripped -not using it as i have a L8. SOLD
1 x L6 ECU fitted with MSD wasted spark driver again in good working order. Bought this from Jasesapphy last year and not used it. Also comes with Stage 3 PTS chip. £200.
1 X Ahmed chip. Stage 3 (3 bar map, dark greens 803) The writting printed on it says 3BL6R21H.803 if that means anything to anyone? £30.
Complete set of tinted rear saph lights, with number plate surround. Includes bulb holders (o/s one cracked slightly) and used seals. A couple of small scratches and marks but nothing major. The plate surround still has the bolts that fix it to rear panel £40.
Momo steering wheel boss (ford hex fitting on the rear) comes with ford centre but has flaked a little. £5
1 x Set of Genuine FORD spark plug leads. They ran fine on my old sapphire, have been sat in the garage since i stripped it. Looks like the mice have nibbled some of the rubber around the top but not much or down to the core. £10.
Full set of Koni adjustables (2WD) with chassis dynamic springs (-30/35mm) Fronts come built up with top mounts and bearings. Springs are rusty and konis need a clean up too. £60.
1 x Full 2wd sapphire engine loom. Worked fine on old car. Could prob do with re-taping. No longer needed as have a new loom from Ryan (carlooms uk) SOLD
I think there are a few more bits but i will post them up later. I can get pick of all the parts, if required just ask.
Thanks
Mart.
Thanks
Mart.
Yeah the Koni's are fine.They are a few years old but were fine on my old car.
Been sat in my garage for months now.The dampers could do with a good clean & the springs are quite rusty and the red paint/powder coating has mostly come off.
PM me an email address and i can send some pics.
Mart.
Mart.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
muz
Sep 30, 2015 08:29 AM
