clunking when turning
Old May 30, 2008 | 07:28 PM
ludaprix's Avatar
ludaprix
Default clunking when turning
Hi guys im not having a great time at the moment with the handling on my car!
when im turning the wheel on near enough full lock it clunks, and ive also got a nasty vibration at 60mph, the car is fine when braking and ok above 70mph, but at 60 its not very nice. below 60 its perfect. had the tracking checked, wheels balanced, even tried another set of alloys, still got the same problem.
it's been suggested the the clunking noise might be coming from the poly bushes?these are in really good condition though!
any ideas?
cheers!
PS forgot to add the car is a saph 4x4
Old May 30, 2008 | 08:05 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Mate this sounds a bit like you just need a little bit of care
Old May 30, 2008 | 10:46 PM
ludaprix's Avatar
ludaprix
what'd you mean mate?
the car is near enough mint, ive looked after it, just a few things letting it down!
Old May 31, 2008 | 10:06 AM
gaz4x4cos's Avatar
gaz4x4cos
i have a similar noise on mine , comes from pass side , mines ok at speed at moment , more when pottering about on shit road surfaces , mines a 4x4 poly bushed too and they are only 6 month old powerflex , so i'm thinking it may be bottom arm ball joint cos i replaced the other side . knew i should have done both at time !
Old May 31, 2008 | 10:28 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Mate I've got absolutely no idea, was drunk when I posted that LOL!
Mine clunks all the time on the offside front, had it looked at, told it was the ball joint but can't afford to be without the car at the moment so I'm hoping it holds together for a while longer.
In the past I have had clunks due to lower arm falling apart, which I am led to believe is very common.
Old May 31, 2008 | 05:17 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
could well be a cv joint
Old May 31, 2008 | 05:20 PM
Mark_'s Avatar
Mark_
as above, my 1st thoughts were cv joint. also if you know for sure its the ball joint a new arm from ford is £40, takes half hour to change so you wouldnt need to be without your motor
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
