ecu chip
hello all... has any1 heard of pts chips? thinkin bout buyin an ecu with this chip in....just wanted to know if they are any good etc? or shud i stay away? cheers in advance
I had one in my old Black s2 worked a treat,depending what sort of power you are after mine had a 16PSI boost limit which was no good for me as i was running 24PSI. Just be aware some have boost limits.
performance turbo systems chips (PTS) are superchip dealers and the only chips I have seen from there for the RST are superchips
Im not a fan of super chips, personally I would only run a turbosystems chip for the RST
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
