Spool-up problem...
Old May 29, 2008 | 05:13 AM
CRASH n BURN's Avatar
CRASH n BURN
Default Spool-up problem...
Hi,
Im not satisfied with the spool-up in my RST. Im currently using a Mitsu 16t turbo. Shall I try n tighten the Wastegate or lose it? Is´t quite sloppy at the moment.
cheers
Old May 29, 2008 | 05:15 AM
R5FORD's Avatar
R5FORD
if your going to do anything to the wastegate get it done from a pro.. as the fuelling will be out.
Old May 29, 2008 | 06:58 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Only if it ends up producing more boost will it (assuming it's EFI, if it's MFI then it'll be fine as long as it's within the remit of the metering head!).
Old May 29, 2008 | 09:34 AM
CRASH n BURN
Im using a HDI-boost controller so the boost wont get to high. Also got a Air/fuel gauge conected to control the mixture.
Soon there will be a extra injector to get enough fuel during acceleration and high boost.
James @ M Developments.
May 9, 2010 09:39 AM
May 9, 2010 08:21 AM
May 2, 2010 09:55 AM
Trader Parts for Sale.
Apr 28, 2010 04:19 PM
Christian and Beccy
Jul 12, 2006 02:39 PM
