Sapphire front bumper removal
I've got a new front bumper to fit to my sapph because the old one is a bit tired but I've got no idea how to remove it and I've not had time to look yet
How hard are they to change and where does the rail bolt to the chassis? I know you've got the side mounts but I've not found the bolts for the rail yet.
Thanks
Thanks
Thanks
Thanks
Fog light wires are long gone hence another reason to change the bumper
Thanks
THEORY is nice, PRACTICE is often different.
The thorugh bolts onto the side supports seize, nearly always, and sometimes you have to be forceful and yank them off, breaking as little as posible in the process.
There is a easy cheap, less than £1 cure that will fix the problem PERMANENTLY though so don't despair, if you need to be a bit brutal.
Free off the height adjusters whilst the bumper is off as a lot easier to do then!
if you want to improve the security and stop little scrotes from having your bumper off by just undoing 2 bolts, remove the headlights and find the location for the height adjusters in the chassis legs
drill a small hole through the leg and adjuster then put a self tapping bolt through the hole
the headlights will cover the bolt heads and no one will be any the wiser
Nice tips guys
I can't believe that the bumper is only held on by 2 bolts
I'm used to Subaru's where you have to remove pretty much the entire front end and shear loads of bolts in the process
The replacement bumper has a side mount broken so I'm hoping and praying I can salvage the mounts on my old bumper and replace the broken one.
i've had to glue mine. did it over a year ago so it'll hopefully be hard now!!. but luckily i bought a new moulding yr's ago so gonna have one nice standard bumper an one modified one...
Hi Tabetha
Could you tell me more about the £1 cure please?
Hi Tabetha
Any more news on the £1 cure?
Hi Tabetha
jessie_rs
11
Jun 3, 2019 04:57 PM
