how to check
thanks for reply . i ask this as im new to all this i picked the car up and it was boosting at 1 bar now its only boosting at 0.5 to 0.8 when it want s to .it just feels like its holding back when i put my foot down . the things ive changed is put an air tec radiator and a k&n cone . spark plugs and leads . cheers
orion=mini saff
it wont hold back if it aint chipped and goes over 10 psi,it will just cut off!make sure ya got the right plugs and gapped right,is it holding back,miss fireing?
ye its holding back its like when you put your foot down some times it will boost a bar then others it will feel flat then change gear then then boost will come back . ha doing my nut in goes in for a new cam this week will this affect the them setting it up , nearly forgot it doesnt misfire . cheers
