cossy wont rev
Old May 24, 2008 | 06:02 PM
a7fco's Avatar
a7fco
Angry cossy wont rev
there is alway something wrong but this has me beat.
car just started to hold back while driving and then cut out it started again but it would just tickover and not rev. towed it home and same again would start but as soon as you touch the throtle it dies changed the plugs and fuel filter as i had some lying around.
put a gauge in the fuel line and it says 0.4 bar (5 psi ish)not sure how accurate the gauge is but does this sound ok.
help someone please
maca
Old May 24, 2008 | 06:05 PM
trevCOSS's Avatar
trevCOSS
help someone please
maca
fuel pressure should be closer to 3 bar with the vac connected to the regulator 3.5 with the vac off so no 0.4 bar is a serious issue, pump mabe
Old May 24, 2008 | 06:19 PM
a7fco's Avatar
a7fco
Wink cheers
cheers trevcoss hope thats the case
rapidcossie's Avatar
rapidcossie
saw a cossie recenlty with a one way valve for the breather on the vac line to the fuel press reg, was giving similar probs.
Old May 24, 2008 | 06:26 PM
Kverna's Avatar
Kverna
Virgin-popper
Your either out of fuel or out of fuelpump(milage )
Old May 24, 2008 | 06:30 PM
a7fco's Avatar
a7fco
i hope yous are right and its just the pump cheers everyone
maca
Old May 25, 2008 | 07:33 AM
Could be a regulator gone duff( you're gauge might be innacurate), so might as well try seeing if you can up the pressure by adjusting it.
I would first though CLAMP the return line, this will ensure you get all the pump pressure, see if it revs ok, don't keep clamp on, otherwise it will be VERY DANGEROUS.
WHEN WAS THE FILTER LAST CHANGED ?
As said pressure with vac on is 3 bar vac off around 3.5 but up to 3.7/3.8 depending on how good your engine is!!
A rewire of the fuel pump is also a good idea, whether it is the pump or not.
Old May 25, 2008 | 09:47 AM
stage 3 muppet's Avatar
stage 3 muppet
possible fuel relay ,does it prime on start ??
Old May 31, 2008 | 10:43 AM
a7fco's Avatar
a7fco
thanx for the help peeps havnt been back on as ive been trying to polish my old turd.
thanx tabs fuel gauge must have been donald ducked as i put on a group a pump and it didnt show much more and it had the pump rewired last year.
cheers stage 3 muppet is the pump relay in the dash next to the ecu as i cant hear it prime before i turn the key the last stage to start it.
cherrs everyone maca
Old May 31, 2008 | 07:02 PM
trevCOSS's Avatar
trevCOSS
mabe the regulator is knackered?
Old May 31, 2008 | 08:14 PM
mechanic28's Avatar
mechanic28
poss regulator can u adjust the pressure or does it stay the same
Old Jun 1, 2008 | 10:50 AM
a7fco's Avatar
a7fco
woo hoo its sorted thanx everybody for their input but in the end it was the 3 bar map sensor but what the hell its back on the road.
cheers maca
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
