clunking noise from rear
Old May 23, 2008 | 08:32 PM
ludaprix's Avatar
ludaprix
Default clunking noise from rear
hi guys, got another problem which had started to occur but i didnt really take much notice of it.
everytime i go over bumps or uneven ground the back of the car is starting to make a clunking noise, the shocks are konis which im sure are fine, does anyone have any ideas about what it could be?
the car is fully polybushed if that makes any difference?
rapidcossie's Avatar
rapidcossie
diff mount?
CV joints maybe?
Old May 23, 2008 | 08:43 PM
ludaprix's Avatar
ludaprix
ive got a feeling that it might be the diff mount, but been told that you can no longer get this part???
Old May 23, 2008 | 08:44 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
anti roll bar links/mounts?
Old May 23, 2008 | 08:46 PM
ludaprix's Avatar
ludaprix
cheers guys i will get my mechanic to have a look at these bits any more??
Old May 23, 2008 | 08:47 PM
AndyPen's Avatar
AndyPen
Easy enough to check though and they do tend to last unless you run massive power. Trailing arm bushes can wear but I'd also suggest the cvs which clack and vibrate like heck when knackered and sound even worse (as does everything) when transmitted through polybushed back ends.
Old May 23, 2008 | 08:50 PM
ludaprix's Avatar
ludaprix
im only running stage one mate, ill go with the cv bushes which i hope are the cheapest lol
Old May 24, 2008 | 05:56 AM
As said just have a good look, ARB bushes are a fave as is a banging exhaust.
You can get a POLY rear diff hanger from mc2racing in the states, or easier from R&B Motorsport(just don't tell him I said so!!)
R&B 01508 557822
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
rsturbo27
Sep 5, 2015 05:08 PM
cossirob
Sep 3, 2015 09:17 PM
