help bloody cosworth won't start !!!
HELP!
Hi, I've got a problem with my 4x4 Saph Cosworth.
Intermittant starting problem. Car will be fine for a few days then suddenly when I come to fire it up it wont start. Good battery and new fuel pump. Car turns over fine but just won't catch. All of a sudden it will decide to fire up and runs fine. Doesn't seem to be any set period of time it turns over without firing up: has been as short as 5mins with 10 attempts or as long as 3hours with 100+ attempts.
Also doesn't seem to be related to the length of time the car been running or if it's been on a short or long journey . For example it cut out today whilst driving on a short trip then wouldn't fire back up for about 10 minutes. After which it ran fine for 5 or 6 fire up's then came it start it after it had been stood for 5 minutes and just turning over , left it 2 minutes caught . Checked plugs not flooding plus also getting a spark .
I was just wondering if anybody has had any similar problem and any recommendations as to what to check etc. I've tried cleaning the sensors. I have changed the injectors, chip, map sensor ( gone for standard to 803's 3 bar map and uprated chip )and it still does it.
please help as otherwise it'll become a bonfire
Thanks guys.
Mike.
Thanks guys.
Mike.
Not common that the actual sensor goes, more often the CONNECTOR to it, so do a wiggle test first, if it doesn't catch.
If first thing in the morning after being stood overnight, LISTEN for fuel pump prime first, as this hows a good clean signal from CPS.
If needed get a CPS from Matt Lewis 01922 692424.
personally i would do as tabetha said ^^^. and also change/check the phase sensor(under distributer cap) and blue water temp sensor.(back of the head near/above dipstick)
Hello again,
Thanks guys. Guess what... turned out to be the crank sensor
. Oil was getting into the sensor connector and with a bit of WD and an air gun the problem is fixed. Since fitted an oil breather and have baught a new crank sensor ready for next time lol.
Thanks for all your help.
Mike.
Mike.
rog
Sep 4, 2015 12:10 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
