ZVH CPS pickup options?
Old May 22, 2008 | 07:56 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Default ZVH CPS pickup options?
I'm gonna be running L8 on my engine when its built and I was all sorted for sensor pick ups etc with 1800 sierra stuff.
If I went ZVH what could I use for a cps pickup?
Old May 23, 2008 | 07:25 AM
Bomber's Avatar
Bomber
Crank Position Sensor - Get a cosworth backet welded to your alloy sump and 4 lugs to the bottom crank pulley.
Phase Sensor (emulation of the sensor inside a cosworth dizzy) - Get a bracket off of Gadget or Jano that fits on the head and reads off a disc behind the cam pulley. Or you can get a hybrid dizzy that uses parts from a Cosworth and a RSTurbo.
Old May 23, 2008 | 07:40 AM
Gadget's Avatar
Gadget
Spanner monkey
Get me a zetec oil pump and i'll get some brackets sorted out to use the standard cvh crank pulley!
Old May 23, 2008 | 10:03 PM
Daveysaff's Avatar
Daveysaff
PM me your number Gary and i'll arrange to send the oil pump to you (along with the dizzy and cvh pulley!!)
Old May 24, 2008 | 07:31 AM
Gadget's Avatar
Gadget
Spanner monkey
Pm'd matey!
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
