compression ????
Old May 19, 2008 | 07:10 PM
SWIFTY's Avatar
SWIFTY
Default compression ????
my mate just done a compression test on his car an one reading was 18psi lower than the other 3 is that anything to worry about the car is runing ok and no smoke.
thanks
Old May 20, 2008 | 05:31 AM
Not worth worrying about, especially if it has a few miles.
In an IDEAL world they would all be within 10% of each other, but I wouldn't personally bother about 18%, as it means stripping bits down.
You could always do a dry then wet test to see if it is rings of valves, it is most likely valves,(or just the tester did not make a good seal on the low one).
What car is it anyway.
Old May 20, 2008 | 03:34 PM
SWIFTY's Avatar
SWIFTY
Thanks Ill Tell Him
Its A 2wd Sapphire Cosworth Its Been Rebuilt Not To Long Back
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
