Actuator hose size anyone?
Old May 19, 2008 | 06:27 PM
kellyjones's Avatar
kellyjones
Default Actuator hose size anyone?
Actuator hose size anyone? the little pipe from the top.....is it a 4mm ?
Thanks
Old May 20, 2008 | 05:33 AM
That's what silicone pipe I use, a bit of a stretch but works.
Or was it 6mm, sorry unsure now, will check later if you want ?
Old May 20, 2008 | 04:07 PM
Paul_RS's Avatar
Paul_RS
I think it is 6mm? I know the first lenght i bought was too small and wouldn't fit over the nipples lol. Helpfully i can't remember what size i got
Old May 20, 2008 | 04:48 PM
xr4man's Avatar
xr4man
i used 4mm. it was a little small but i got it to stretch. 6mm would probably be perfect.
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
