external wastegate
A turbo that isnt internally gated (or you can wire the wastegate shut on it)
An external wastegate
A pipe from the manifold to the external gate
A pipe from the external gate back to the exhaust to keep it all silenced nicely
Thats about it really, boost control shouldnt need a change in hardware but may need the settings changing depending on how you run it.
Ps 400 quid ish as a ballpark I guess
Just a guess though!
ive got a turbonetics evolution w/g fitted , but then im also run a t34 at 1.5 bar with a screamer pipe(wg pipe is just below the radiator) sounds awesome when wasting.
for starters , you need a external wg and a place to plumb it to , dont think it can be done on the std manifold. my cast manifold has a flange for it , you may need to get a custom manifold fabricated.
external wg's make in car boost control easier , but only become useful with big turbos with high boost
Trouble is these days, even some of the better known "copies" are now in fact fake, lol
May 31, 2016 09:28 PM
Aug 14, 2015 07:29 AM
