fao any electrians
Old May 17, 2008 | 12:35 PM
turbo1973's Avatar
turbo1973
Default fao any electrians
the lights in my building have blown a fusebut not sure where the fuse is it the white box up in the corner and what fuse would you put in or would it be the grey thing with s/l above it
Old May 17, 2008 | 12:40 PM
KSA-Cossie's Avatar
KSA-Cossie
Would imagine it'll be 6 amp,what lights are in your building ?
Old May 17, 2008 | 01:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the white box looks like it's connected to the grey box at the top as well
turn the grey box off before you unscrew the small screw that holds the fuse in the white box
replace with teh same size fuse
if in doubt, spend money on doing it properly
Old May 17, 2008 | 01:02 PM
KSA-Cossie's Avatar
KSA-Cossie
Pic wasn't there when i replied,white box is fused outlet,i would check the fuse in the grey one m8.
Old May 17, 2008 | 01:04 PM
turbo1973's Avatar
turbo1973
the one with s/l above it
Old May 17, 2008 | 01:08 PM
col cos1's Avatar
col cos1
2 phase and neutral...lol
Old May 17, 2008 | 01:09 PM
col cos1's Avatar
col cos1
check the singles clipped to the wood...............im condeming it
KSA-Cossie's Avatar
KSA-Cossie
No the one with mem on it.
Old May 17, 2008 | 01:10 PM
fish99's Avatar
fish99
what cowboy did that? its a mess.... trying to look at it I would say its the fused spur in the top left corner.. to be ultra safe switch off the grey box on right with mem on it. unscrew fuse cover on fused spur, put new fuse in and try it again.. depending what lights you have in your office it may be that 6amp is a little on the low side
that instal really needs a proper dis board putting up
KSA-Cossie's Avatar
KSA-Cossie
I'll second that.
Old May 17, 2008 | 01:14 PM
fish99's Avatar
fish99
I dont think they have heard of conduit.
Old May 17, 2008 | 01:33 PM
turbo1973's Avatar
turbo1973
would there be a fuse in the grey box with mem on it
Old May 17, 2008 | 01:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Yes,should be a rewireable one.
Old May 17, 2008 | 01:37 PM
turbo1973's Avatar
turbo1973
so what box will i open grey box or white one
Old May 17, 2008 | 01:48 PM
KSA-Cossie's Avatar
KSA-Cossie
You can check the grey one easier as the fuse in the white one will require amutimeter tocheck it.
Old May 17, 2008 | 02:02 PM
turbo1973's Avatar
turbo1973
so whats the one with s/l above it would that not be stair lighting
Old May 17, 2008 | 02:13 PM
dazzle740's Avatar
dazzle740
if i was you i get some one in to re-do the entire lot, as what you have at the mo is an accident waiting to happen.
Old May 17, 2008 | 02:48 PM
mackers's Avatar
mackers
Definately an accident waiting to happen, thats a mess. Get a spark in to tidy that up mate.
Old May 17, 2008 | 02:49 PM
turbo1973's Avatar
turbo1973
heres the pics what do i need to do to fix it
Old May 17, 2008 | 02:53 PM
fish99's Avatar
fish99
that should be re wirable with appropriate fuse wire... but looking at that it looks fooked. basically u have taken out the rewirable fuse , but there shoul be screws either end if it where you can secure the fuse wire. is it my eyes but has one of the ends totally melted?
Old May 17, 2008 | 03:06 PM
danneth's Avatar
danneth
TORQUE!
looks like a friday afternoon job get it sorted right mate
Old May 17, 2008 | 03:21 PM
McGoo 69's Avatar
McGoo 69
ive seen alot lot worse on manchester uni
Old May 18, 2008 | 03:04 PM
turbo1973's Avatar
turbo1973
ok it says on fuse 20a but i only could get 15 or 30a fuse wire is it ok to use 30a or should i just use 15a
Old May 18, 2008 | 03:48 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
holy!! you've got a pretty crazy setup compared to us here in norway!
Old May 18, 2008 | 05:03 PM
KSA-Cossie's Avatar
KSA-Cossie
That install aint the norm over here m8.
Old May 18, 2008 | 05:19 PM
xr3-keith's Avatar
xr3-keith
shocking, i would a sparks in asap, good luck mate
MikeyRobbo
Jan 29, 2012 07:03 PM
Chris S
Jan 4, 2007 07:11 PM
Disabled Account
14
Oct 25, 2005 06:55 AM
Disabled Account
Jun 14, 2005 06:17 PM
