t5 clutch lever retaining clip
May 16, 2008 | 09:51 PM
has anyone got the clip that locates the clutch lever into a t5 box hope someone can help thanks neil
May 19, 2008 | 08:17 PM
CLIP
I Was Told These Were Like Hens Teeth .i Have Used A 13 Mm Bolt Screwed In Bellhousing With Threads Ground Off So Its Smooth ,worth A Try
May 20, 2008 | 11:05 PM
can you do a picture if possible
and explain what you do exactly please
it sames to be very hard to find this clip
thanks
May 21, 2008 | 06:47 AM
Quote:
Originally Posted by
florent78
thanks
quite corect this item is very difficult to find thats not broken,I have 3
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
