Axle stand location
Old May 15, 2008 | 12:26 PM
tsutton's Avatar
tsutton
Default Axle stand location
Some say I should put the axle stand at the furthest away from the wheel, other say next to the wheel - which is correct?
Photo - http://www.hypergallery.co.uk/fordst170/P1000951
This is for Ford Focus ST170 (But I'm sure it's the same for normal Focus)
Thanks,
Old May 15, 2008 | 12:27 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
One on the right....
Old May 15, 2008 | 12:28 PM
tsutton's Avatar
tsutton
That was a quick reply! Thanks.
I'm assuming the one on the left is a no no even that someone said they used it?
Old May 15, 2008 | 12:30 PM
Charlie Chalk
Unknown.
TBH, I think both would be OK, But the one on the right seems to be shaped for an Axle stand.
Old May 15, 2008 | 12:46 PM
tsutton's Avatar
tsutton
Thanks.
Is it okay to have one fitted on the left side of the car? Or do I have to raise both front sides?
It will only need to be raised for about 20 mins or so.
Old May 15, 2008 | 12:47 PM
Charlie Chalk
Unknown.
Just use a jack then if your doing one side?
Old May 15, 2008 | 12:49 PM
tsutton's Avatar
tsutton
Not high enough. I need to work under the car.
Hence using the jacking and supporting it up with axle stand. But not sure if I ned to raise both side or one side?
Old May 15, 2008 | 12:52 PM
Charlie Chalk
Unknown.
Do both side then mate, I get para about using one
Old May 15, 2008 | 12:55 PM
tsutton's Avatar
tsutton
Thanks.
Last question, I think!
Can I jack up one side, put in axle stand, lower it. Then jack up the other side, put in another axle stand and lower it?
If so, would the 1st axle stand "move" when I jack up the other side?
Old May 15, 2008 | 12:57 PM
Charlie Chalk
Unknown.
Should be fine mate
foreigneRS's Avatar
foreigneRS
Testing the future
never, ever
Old May 15, 2008 | 12:59 PM
Charlie Chalk
Unknown.
never, ever
I do if its a quick job My jacks got a lock on it though tbh
Old May 15, 2008 | 01:42 PM
I think axle stands should be banned, bloody dangerous things IMO.
I use a old railway sleeper cut into squares, as you have a CHEAP nice big area, that is not going to tip like a axle stand.
Old May 15, 2008 | 02:06 PM
jammy86's Avatar
jammy86
Originally Posted by tsutton
Thanks.
Yes it will move a little. just be careful as you jack the car up. trolly jacks are meant to move inwards as they jack up since the jacking point moves in a circular path. so push the jack in as you jack. NEVER take your eye off the first axel stand and if its moving too much stop and start again.
JAmes.
Old May 15, 2008 | 02:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
we all do, but we shouldn't
Old May 15, 2008 | 03:05 PM
RichieST's Avatar
RichieST
I used to jack my focus up on top of that big bolt thats to the right of the two red circles, then put the axle stand on the sill.
Old May 15, 2008 | 03:21 PM
Charlie Chalk
Unknown.
Not seen many on Ebay... LOL
Old May 15, 2008 | 04:30 PM
Garden centres or reclamation yards around £8-£14.
Old May 15, 2008 | 05:10 PM
tsutton's Avatar
tsutton
Thanks all, have successfully jacked up, put in axle stands and put them down.
Now one left which I will make a new post...
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
AJC
Oct 1, 2015 06:47 PM
Steve Escos
Oct 1, 2015 06:57 AM
