Steering column thingy
Age old problem this, certain Land Rover discovery ones are the same, or so close they can be used, some people just put a group 4 joint in there though solves the problem on a permanent basis then.
Where would I be able to get the group 4 part from??
it was the way no-one told him what it was called and just said get a group 4 one.
you cant ring someone up and say can i have a grp4 steering clumn thingy can you.makes you look a plank
What a F--king nightmare for such a poxy part!
yeah sorry it is a 2wd bit but thought it might have helped and given some ideas of possible things to try as from the pictures they look roughly the same and also give ideas of which bushes to try from other cars
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
