autronic smc
comes just about ready to use with a flying loom with all connectors on, comes with air charge temp sensor, fuel pump relay ect. can be used on coilpack/wasted spark or dizzy. comes with manual ect.
feature ready ecu £600 ono
Features:
Sequential operation for 2 to 8 cylinder engines.
3D fuel and Ignition maps.
User defined up to 32 RPM and 16 Load sites = 512 sites.
Anti-Lag.
Flat Shift (ver 1.19).
Data Logging.
Software selectable trigger angle.
Support for multi-tooth or missing teeth triggers.
Auxiliary outputs other than fuel pump control
8 cyl engine = 1 (1 PWM output).
6 cyl engine = 3 (1 PWM + 2 On/Off)
4 cyl engine = 5(1 PWM + 4 On/Off)
Auxiliary outputs can be defined for boost control, nitrous oxide, camshaft
timing, AC, fan control, idle valve etc...
Available with high current drivers if required.
AutoTune option available.
Optional Water Proof case for marine or harsh environments
Features:
Anti-Lag.
Data Logging.
extra15
28
Nov 8, 2005 10:05 PM
