Turbo damper (head scratcher)
Got all the bits and for the life of me can't work out how the feck it all goes together as you'll see in the pictures
Turbo damper - the bit that comes down doesn't look long enough to reach to the bracket if that were fitted
damper bracket - been told by CR turbo's it goes in place of one of the rings on the turbo
Any advice, or am i running the wrong manifold or something???
Sorry can't help, mine went on without any problems...
However (hijacking thread alert
), since installing mine I still get a little "zing" sort of noise at 3.5K or so.
I've followed installation instructions to the letter... should I give the hanger bit another turn to create more tension, or, is that normal with these dampers (had the original one before it decided to throw a wobbly and drop bits on the m-way
The thing is the bolt behind the oil feed doesn't come out as the space isn't there.
This is what's confusing me and thats the only way i can see it goes on to work with the damper, if i use another bolt down the main hole will be too low down.
I look forward to seeing how others are done.
Matt Baxter
Sep 16, 2015 08:30 PM
