escos electric windows.
Old May 13, 2008 | 02:55 AM
ossie cossie's Avatar
ossie cossie
Question escos electric windows.
Acouple of questions.
1, Is the escos electric window switch the same as a MK3 fiesta, and is the wiring plug the same?
2, Do any of the escos,s come with a switch that will automatically lower the window all the way down, sort of push a little for manual control or all the way down for auto. like the more modern cars of today?
Old May 13, 2008 | 05:28 AM
The feature you refer to is termed ONE TOUCH, don't know when they came out but they were on my MK1 mondeo(1995), but only on the drivers window on these.
They are so easy to add, have got them on all four windows on my cossie sapph, they are not even expensive new, you cand even add them to the lecky sunroof or the UP motion as well as the down motion of the windows.
Only FOUR wires to do, live earth and then the two wires to the widow switch after you have cut into the wire that goes LIVE when doing what you pressed, orientation is needed but easy.
ps I have 8 in my garage
Old May 13, 2008 | 04:37 PM
MarkN's Avatar
MarkN
Mk3 Fiesta switches are the same as Escort Cosworth ones.
No Escort cossies came with one touch from the factory - not even the small turbo ones.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
pabloXR
Sep 21, 2015 12:42 PM
Mickeystewart
Sep 9, 2015 04:04 PM
