Saffy speedo...
Old May 12, 2008 | 09:16 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Default Saffy speedo...
Ok so i'm trying to be gentle with the new car an not going for the usual bish bash bosh method.... blah blah blah
Does the speedo cable just pull out or screw out or what? at the back of the speedo.
Was at it for about an hour tonight in the garage before calling it a nite.
Old May 12, 2008 | 09:18 PM
rapidcossie's Avatar
rapidcossie
two small pieces of metal either side that hold in into the clocks?
these unscrew if I remember right?
Old May 12, 2008 | 10:17 PM
AndyPen's Avatar
AndyPen
Takes a bit of a squeeze to release the plastic pins which sit in a groove on the back of the speedo mate. The plastic is usually quite hard and its designed a bit like those childproof lids where you have to squeeze in the right place. Once its off you'll wonder why it was so difficult!
Old May 12, 2008 | 10:40 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Cheers lads. I'll set about that tomorrow sumtime..
Old May 13, 2008 | 05:20 AM
As said you can feel the serated raised bits that you squeeze, just a gentle squeeze is all it takes.
Old May 13, 2008 | 12:29 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
damm i'm an idiot!!
Note for future: squeeze one side only. side with the biggest lug. utherwise your pushing against yourself, the harder you squeeze-the more it grips.
Shit, such a simple task
Old May 13, 2008 | 09:58 PM
AndyPen's Avatar
AndyPen
amazing aint it - I think everyone struggles first time around!
RSKim
23
Feb 21, 2006 05:07 PM
ellicoss
Oct 17, 2005 05:53 PM
RSKim
Sep 5, 2005 11:14 PM
RSKim
15
Aug 5, 2005 08:00 AM
