Throttle position sensor on saff cossie 4x4
How easy are these to change and do you have to take the throttle body off to get to the sensor. Ive got a daft fault on my car when im driving it the car will chug every now and then. Sometimes when im driving it the car just goes on its own when i take my foot of the throttle pedal. It feels as if the choke has come on and the it goes back to normal. Im thinkin that it could be a faulty throttle switch.
crank sen, ecu pins 3&4, 600-1000 ohms
phase sen, pins 5&23, 700-1200 ohms
charge sen, pins 11&31, @10c=6000 ohms @ 20c=3750 ohms @ 30c 1600 ohms
temp sen, pins 11&29, @10c=6000 ohms @ 20c=3750 ohms @ 40c 1600 ohms @ 60c=750 ohms @ 80c=380 ohms
map sen, pins 11&30, 50-600 ohms & pins 15&30, 500-6000 ohms
Anutternutter
Aug 21, 2015 06:07 PM
Zoggon
Aug 10, 2015 10:39 AM
