Cossie misfire
Old May 11, 2008 | 09:49 AM
timster's Avatar
timster
Default Cossie misfire
Hi everyone my 4x4 cossie has developed a misfire at low revs i.e. 20mph 2nd gear,seems okay when you put it to go anyone else had this?Took the cap and rotar arm off yesterday they looked fine and sprayed some electrical contact cleaner on the multiplugs in the engine bay.Thanks for any help in advance
Old May 11, 2008 | 01:08 PM
mechanic28's Avatar
mechanic28
what plugs have u got fitted?
Old May 11, 2008 | 01:12 PM
KSA-Cossie's Avatar
KSA-Cossie
And what gap ?
Old May 11, 2008 | 02:19 PM
timster's Avatar
timster
The pp8 ones,0.7 gap.
Old May 11, 2008 | 02:21 PM
What is the CO set to ?
Old May 11, 2008 | 04:12 PM
timster's Avatar
timster
0.5% one of stu's closed loop stage one,the plugs are brand new
Old May 11, 2008 | 04:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Have you tried the old plugs back in m8 ?
Old May 11, 2008 | 05:06 PM
timster's Avatar
timster
It was doing a similar thing before,might go down the route of changing the cps,phase sensor,ignition amplifier
Old May 11, 2008 | 07:29 PM
Don't just change for the sake of it, check the switching speed of the Lambda.
Old May 12, 2008 | 06:34 PM
costina's Avatar
costina
Live long and prosper!!
0.5 % is too low imo needs to be .8 .9 plugs gaps 0.6mm
Paul
Old May 22, 2008 | 04:09 PM
timster's Avatar
timster
Used some contact cleaner on the multiplugs above the rockercover and used the car three days on the trot and its all good! no misfire since tuesday
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
