Electrics
For some reason the indicators on my 3 door work some times and sometimes they dont do anything. When the indicators dont work neither do the brake lights or reversing lights. All the other lights still work and so do the hazards?
Any ideas what this could be please?
first look at the connectors in the rear light cluster
then the switch/stalk itself
then the relay
do they work and then not work and then work on and off or are there times when they won't work at all?
have you swapped the fuses over?
then the relay
