escos roof lining
I need some help. I am changing the manual sunroof in my escos to an electric one in the near future, i have the whole sunroof including motor,switch and plastic cover what i need to know is do i just cut out the excess headlining card to fit around the motor, and then put the switch and cover back on? Also would i have to run wires to the motor? Does the switch lightup when you turn the lights on like the electric window switches? and last of all the headlining on my car is a bit saggy it looks like the material has come away from the card, what is the best way to fix this while i have the headlining out? Also just remembered that some of the door panels (the soft ones on the front doors) are doing the same thing looks like the material is coming unstuck. Thank for the help.
the standard switch doesnt light up although this can be converted quite easily,no need to change the switch either, i did my last one, think its steve off here who told me how to do it
