What Piston Rings
Old May 9, 2008 | 08:37 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Default What Piston Rings
Hi all
Well i got the call from my engineering shop to say that my block, crank, flywheel, pistons and head are ready for collection after having some work done on them.
The shop has got me some Heavy Duty standard size big/mains bearings, thrust washer etc but im just wondering what piston rings to go for.
I will be aiming to build a solid engine to produce a nice 220bhp on standard pistons but is there better quality rings on the market ???
I noticed that Burton do OE rings sets for £79 or NON Standard for £109.
Can someone enlighten me in what the difference is with standard/modified
piston rings and what would you recommend for the power i want to achive??
Really dont fancy shelling out £515 for Accralites
The work iv had done is as follows
Block acid dipped/cleaned
Bores fully deglazed/Honed
Top / sides refaced
Crank & Flywheel - lightened, balanced, polished & refaced
Head/pistons chemicaly cleaned
CheeRS
Kris
Old May 12, 2008 | 07:57 AM
jld0211's Avatar
jld0211
hi im having my bottom end rebuilt at the mo and everyone i have spoke to have recommended mahle pistons or other german companys pistons
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
