full zetec in mk4
Old May 8, 2008 | 05:52 PM
instain's Avatar
instain
Default full zetec in mk4
well ive decided after a long debate and a tappet chewing the head of my engine, to full 1.8 zetec my efi xr3i but i havent got a clue what parts i need and what wires need splicing into any 1 give me some clues plz
Old May 8, 2008 | 07:16 PM
macturbo's Avatar
macturbo
Whats your mk4 currently running?
If you have an efi management its a doddle really.
Mine was a 1.4 cvh carb.
Im now running a zetec turbo.
Click on my sig for more pics if you want.
You will need a modified rear engine mount.
EFI managent or carbs if you wish, twin 40's maybe?
Either a Fiesta RS turbo EFI inlet or the later EFI inlet as found on the mk6 escorts.
Fiesta turbo inlet needs an adapter plate to mate to the zetec head, the later inlet bolts straight on but not sure what injectors you need to run on it really.
Either use the zetec exhaust manifold and have a matching down pipe altered to fit your car or you can drill and tap the head as I did and bolt the cvh manifold on.
CVH gearbox bolts straight on so no worries there.
You need to find a suitable hose that will fit the larger zetec waterpump outlet.
You need the later mk6 escort top hose with the fan switch fitted to it.
Earth the negative wire from the temperature sensor to the engine as the cvh engine has a aluminuim housing and thus is the earth whereas the zetec housing is plastic and therefore needs an earth.
Cant remember anything else being needed but im sure theres a few people who can either add or change what ive wrting above for you.
Old May 8, 2008 | 09:20 PM
instain's Avatar
instain
cheers for that i am running efi at the moment so that should be easy just need to kno if i goota cut into the loom for the ecu
Old May 8, 2008 | 10:07 PM
fonfe's Avatar
fonfe
if you go for n/a just get a 1.8 zetec with loom and pre pats ecu.
mod the engine mount but cutting off one of the lugs and welding another one on + drill the hole.
wiring is easy www.s2rs.co.uk have the diagrams on the site forum and a fair few people have done the change on there. i just took my 1.8 zetec out of my mk4 and put in a rs2k i4 lump so trust me na zetec is easy peezy and it will be BETTER on fuel than ur 1.6 xr3i is with more power so its a win win situation i think.
best way to do the mount is get a spare and do all the welding on that using the zetec for reference of which lug and the extra hole you need to weld on/drill out then when you do the swap its one in one out. pics of the mount are here:
http://www.escortupgrades.co.uk/Escortupgrades.html
i didnt weld the extra tube support and was using 130 spec lump and had no problems at all with it, had it in for a year then took out tuesday was a good conversion nice and simple yet a fairly good end result
Old Jun 23, 2010 | 07:01 AM
njietro's Avatar
njietro
retr0<3
Do someone have some pics about it?
Even when starter motor is right under the intake manifold?
I bought an 105bhp 1,8 zetec from 96 Escort, and im not sure does it fit into my mk4 1,6's original gearbox. In cvh starter motor is under the exhaust manifold, and in that zetec it is under the intake What gearbox do i need to get that zetec work in mk4?
Old Jun 25, 2010 | 09:59 PM
forevaford's Avatar
forevaford
a mk4 gearbox.
Old Jun 26, 2010 | 08:11 AM
Smiler's Avatar
Smiler
I was about to point you in the direction of my far from complete website but fonfe beat me to it. Cheers fonfe!
Old Jun 26, 2010 | 11:00 PM
njietro's Avatar
njietro
retr0<3
Originally Posted by forevaford
a mk4 gearbox.
Thanks man.
Motor is now in place with mk4 gearbox.
How im ever going to get all the engine electrics done? I have full pack of Zetec wires, but i have more ports/terminals in that zetec wires that i can find from my zetec engine. :S
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
imnoteasy
Sep 7, 2015 09:26 PM
