crank - flywheel zvh Q ???
Old May 8, 2008 | 05:02 PM
B1G_RST's Avatar
B1G_RST
Default crank - flywheel zvh Q ???
ok drilled the holes on my cvh flywheel too 11mm as i was told to do but stil dont line up with the zetec crank,
its a 1.8zetec bottom end im using,
cheers for any advice
sean
Old May 8, 2008 | 05:03 PM
jacko's Avatar
jacko
turn it round one set of holes at a time mate they will line up the 1.8 and 2.0 crancks are the same
Old May 8, 2008 | 05:09 PM
B1G_RST's Avatar
B1G_RST
so its deffo 11mm theve to be bored out too ?
cheers
Old May 8, 2008 | 05:19 PM
jacko's Avatar
jacko
yeh mate it will just turn a few times and it will fit all the bolt holes are off centre
Old May 8, 2008 | 05:31 PM
B1G_RST's Avatar
B1G_RST
perfect thnks jacko (Y)
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
davidfordrs
Sep 21, 2015 04:23 AM
