ford focus tdi
I'm after some ideas i have a focus turbo diesel on a 53 plate and it has decided to start to blow the 15amp fuse which belongs to the indicators and hazard lights. It is very intermitant and some times the fuse can last a few days and then blow. the car has never had a tow bar fitted so there is no moody wiring on it, the car is bog standard nothing after market on it at all.
I've checked all the bulbs and holders and had the bsi unit checked, all ok.
Has anyone had this at all.
It's so intermitant that i can't even tell you if it's the right or left that is blowing the fuse.
when the fuse is blown everything else works so it only controls the indicators.
I've now put a 10amp resetable breaker in instead of the fuse in order to try and make it blow a bit more frequently but no joy as it hasn't blown since thursday last week.
Anyone had this on any form of focus????????
thanks in advance,
Phil
thanks in advance,
Phil
