back firing at high revs
Old May 7, 2008 | 09:32 PM
smitsturbo's Avatar
smitsturbo
Default back firing at high revs
im new to cossies so help me out
my 2wd saph backfires & splutters at high revs so whats the crack there as its hampering its performance a bit & the boost is peeking at around 14psi
it has green injectors, bajoo chip, rs 500 intercooler, collins actuater, 3 bar map sensor, k&n & stainless exhaust & maybe a hybrid turbo but im not sure, has dyno graphs for 340bhp
im thinking maybe a set up as it sat for nearly 8 months plus, i havent changed the plugs & leads yet either
cheers
Old May 7, 2008 | 09:37 PM
KSA-Cossie's Avatar
KSA-Cossie
Plugs would be a good start,if it was me i'd change fluids cam belt etc too .
Old May 7, 2008 | 09:44 PM
rapidcossie's Avatar
rapidcossie
change everything you can afford to as it will all need doing at somepoint!
Old May 8, 2008 | 06:47 AM
Good advice, just change the usuall suspects, ie plugs, make sure it has decent leads, inspect the insulation on the phase sensor, change the CTS, get it set up for peace of mind.
Do the FUEL FILTER as well, although this small item will not give the misfire, it is so often neglected, but is so easy to do, ok then it can be a royal pain in the rear with brackets breaking etc but is important!!
Old May 8, 2008 | 07:33 AM
smitsturbo's Avatar
smitsturbo
ok i'll get strait on to that today, what sort of boost should a car of this spec be running would you say??
Old May 8, 2008 | 07:59 AM
Smit's Avatar
Smit
The 60ft Launch King
around 20-22 boost would be fine boss
Old May 8, 2008 | 12:37 PM
I would set it very low, and take it to a rolling road for a fuelling check etc where they can adjust it to what chip supplier says is correct for the chip.
On this power usually around 24/26psi.
Old May 8, 2008 | 12:40 PM
KSA-Cossie's Avatar
KSA-Cossie
If dark greens id say 26 psi although i ran mine on 28 lol.
Old May 8, 2008 | 02:00 PM
JamesH's Avatar
JamesH
Thats fine mid range, but high up you're likely to blow it up
And seeing as this guys just bought a Cossie, and will want as much power from it as possible, I'm sure he'll set it to 28psi and it'll be fine for a couple of weeks lol
Old May 8, 2008 | 02:17 PM
KSA-Cossie's Avatar
KSA-Cossie
Although i did ask stu @ MSD if that was ok to do 1st .
Old May 8, 2008 | 02:30 PM
JamesH's Avatar
JamesH
You never know how accurate the gauge is tho
Old May 8, 2008 | 02:44 PM
KSA-Cossie's Avatar
KSA-Cossie
secs monitor james,but get your driftpal.
Old May 8, 2008 | 04:52 PM
smitsturbo's Avatar
smitsturbo
ok ive been a bit busy today but popped in to halfrauds to get plugs, leads & oil but they dont sell the plugs & leads so where would you recomend i get them & what kind??
cheers
Old May 8, 2008 | 05:10 PM
LHD220Turbo's Avatar
LHD220Turbo
matt lewis off here
Old May 8, 2008 | 05:55 PM
As said Matt Lewis 01922 692424.
Old May 8, 2008 | 08:40 PM
smitsturbo's Avatar
smitsturbo
he only sells standard items, are there fancy ones availible?
Old May 8, 2008 | 08:59 PM
KSA-Cossie's Avatar
KSA-Cossie
MSD sells leads and plugs m8.
Old May 8, 2008 | 09:10 PM
smitsturbo's Avatar
smitsturbo
just orderd them online at burtons
Old May 9, 2008 | 05:46 AM
I am sure Matt Lewis sells 909 leads, which are excellent leads.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
ekjim
Aug 17, 2015 08:57 PM
