Ofac and Ofab air sensors
Old May 7, 2008 | 07:35 PM
Pat's Avatar
Pat
Default Ofac and Ofab air sensors
I`m after a quick answer, how do i know which air sensor i have.. I have been told that i should have an OFAB air sensor on my 2.1 zvh..
how can i tell??
Old May 8, 2008 | 02:08 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
i 'think' the ofab is a square 2 pin connection and is screwed into an adapter but the ofac is just a big round plug one,others will confirm tho!!
Old May 8, 2008 | 07:57 PM
MarkN's Avatar
MarkN
OFAB and OFAC air temperature sensors are both the same. They look like a black rod and have a two pin plug on them. It's the normally aspirated ones that have the round plug.
Unless you are talking about MAP sensors that measure air pressure... In which case they are different.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
