moosing and secondaries mondeo
Old May 7, 2008 | 06:20 PM
juffer's Avatar
juffer
Default moosing and secondaries mondeo
Hi
How do i stop my mondeo st24 v6 from moosing and making that stupid noise? Also what gaskets do i need to replace to clean my secondaries. Thankyou geoff
Old May 9, 2008 | 04:06 PM
juffer's Avatar
juffer
cough
Old May 9, 2008 | 04:21 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Sorry no idea
Old May 9, 2008 | 04:23 PM
DanCossie's Avatar
DanCossie
Post Whore
aint got a clue what your talking about mate
Old May 9, 2008 | 04:47 PM
groomers's Avatar
groomers
there is a kit form ford to replace some of the pipes cant remember which ones though!
dont know what gaskets you wil need-sorry!
Old May 9, 2008 | 05:02 PM
tt4's Avatar
tt4
Mondeo V6 idle too high, 'MOOSING'
All Mondeo's equipped with the Duratec V6 experience this.
Ford thmselves put it this way:
Our (incomplete) understanding is that it's pretty easy to tweak an engine for low emissions in steady-state operation; it's the transients that kill you. Because of this, engines have long had devices to hold the throttle open temporarily. I suspect that altering this will increase emissions. And I would expect that the program that decides when to keep the throttle open is complex enough that you won't be able to predict it.
-Stephen H. Westin
swestin@ford.com
HERE'S THE FIX
Turns out that "they all really do, do that." Sucks, but I concluded it is built into the smog calibration in the ECU as Ford always maintained . It's implemented by the air bypass valve position which is controlled by the ECU. What this valve does is bleed air from the rubber intake connector tube prior to the throttle body directly into the manifold. This effectively controls RPM under various conditions.
The "throttle hang" fix consists of installing a restrictor plate in the form of a 1/2" COPPER pipe (stop end) cap inserted INSIDE the 3/4" rubber hose that supplies air to the bypass air valve. The cap is inserted at the manifold end of the hose and fits either the original or Mr. Moose hose. It also has a black tank, about the size of a fruit juice can, right under the throttle/CC cables. This plug has a hole drilled in it to provide sufficient air for idle RPM control but insufficient to maintain a RPM of in excess of 3K. The throttle drop is still slower than I would like but the "hang" is gone and that's a biggie.
For the SVT, or a car equipped with the SVT intake, the optimum hole size in the plug seems to be 3/16" or 7/32". For the stock intake, the best size seems to be 15/64". There are reports that the plug causes newer SVT's (E1) to lose power in mid-range RPM's, perhaps due to the newer IAC valves? The addition of the throttle hange restrictor plug has been reported to also fix the Mr. Moose (see related section on this page) issue without using the Ford Moose "bagpipe tube/hoses."
I removed the tank also but don't think this is necessary. I just pushed the plug into the 3/4" hose at the manifold end. For removal, a pair of pliers works well. The first time I started it, the engine "hunted" before stabilizing at 750RPM idle. Did this for when the lights were on and the AC. The ECU is learning the new position of the valve for maintaining the programmed RPM, which is normal. After two or three starts, it acts normal.
I would suggest getting several plugs-they're cheap-and trying different size holes. It needs to be just large enough to maintain cold or warm idle RPM's under worst case accessory loading. I assume this is cold day, cold start with the air on in defrost mode. Installing the plug is about a 3 min job once the hose is free and easily removable. Be sure it isn't cocked. Some WD-40 helps. It needs to be in far enough so that the hose fits on the nipple as per original. It will be too large to get into the mainfold.
Total cost is about 15p
Courtesy of Cosmo V6
Old May 9, 2008 | 05:19 PM
juffer's Avatar
juffer
thankyou for the help.
Old May 9, 2008 | 07:31 PM
anodised's Avatar
anodised
just go to ford and ask for the kit it dont cost much and is easy to fit
not a very good pic do the bit you replace is up by the brake res
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
