Plug gap?
Old May 6, 2008 | 08:48 PM
lamb chops's Avatar
lamb chops
Default Plug gap?
Anyone have an idea of what gap i should be running with HKS iridium (spelling) plugs? The car is stage 3 24 pSI peak holding 21 ish.
I have a missfire at the mo under full load and im thinking perhaps the gap is to big and its getting blown out??
Cheers chaps
Old May 6, 2008 | 08:50 PM
KSA-Cossie's Avatar
KSA-Cossie
0.65 mm m8.
Old May 6, 2008 | 10:00 PM
lamb chops's Avatar
lamb chops
Great thanks!! will check that tomorrow
Old May 8, 2008 | 12:51 PM
You won't FEEL a mis as such, but hit a massive flat spot, still be nice and smooth, if it the spark getting blown out.
Mine are gapped at 0.85mm, with a group a coil, magnecore leads, and using IK31 plugs, if that is any help, on similar boost.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
