Cosworth Rebuilt Engine
200 Block (either .75mm or 1mm) Need to check
Full strip and Rebuild all items decoked
New Rings
Standard Comp not a mark on any pistons
All new Race Bearings (ACL)
Polished Crank
All New Seals
ARP Rod Bolts
Rods checked and balanced
2wd Sump
New Oil Pump
New Water Pump
ARP Fly Wheel Bolts
4x4 Fly wheel
4x4 Head
Comes with Standard Cams
New Lifters, Valve Guides, New cam bearings, New cam Seals,
Head only had one skim
4x4 inlet with ALL new sensors
2wd Exhaust Manifold in excellent Condition
Engine Mounts fitted
Has New belt to go on and a new tensioner and will come with a Group A Head gasket and head bolts
Apart for inspection
Have Repceipts for strip down and rebuild of £3K, not including the£1K spent with Matt Lewis on head gasket, Water Pump, Tappets and other stuff e.t.c
Looking for Offers
New Rings
Polished Crank
All New Seals
ARP Rod Bolts
2wd Sump
New Oil Pump
New Water Pump
ARP Fly Wheel Bolts
4x4 Fly wheel
4x4 Head
Looking for Offers
rog
Sep 4, 2015 12:10 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Aug 14, 2015 07:29 AM
