4X4 HEAD
Old Feb 2, 2004 | 10:25 PM
Default 4X4 HEAD
Iam going to buy a 4x4 head this weekend , is there any part no's to check ?
How do you tell it apart from 2WD item if it has no rocker cover?
Old Feb 2, 2004 | 11:18 PM
Toe Knee's Avatar
Toe Knee
4x4 ones dont have a temp gauge at the front right of the head like 2WD ones do, rahter than having the sensor or a threaded hole for it it'll have just a blank face, also thing the combustion chambers are different IIRC................
Old Feb 2, 2004 | 11:27 PM
RobS's Avatar
RobS
also 2wd has a mounting plate for turbo damper on it 4x4 aint, u cant miss that
Old Feb 3, 2004 | 06:26 PM
THANKS !!!!
Old Feb 3, 2004 | 09:34 PM
What is the std top to bottom measurement for the 4x4 head?
What is the most which can be skimmed off
I really need origional thickness and minimum thickness
Thanks
Old Feb 8, 2004 | 12:06 PM
alan rainbow's Avatar
alan rainbow
also the oil feed for the turbo comes off the side of the head
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
pie-face
Sep 15, 2015 10:43 AM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
