S2 to S1 rear windows
I'm looking to fit the pop-out rear windows from the S1 to my S2, what do i need other than that actual popper unit? I'm guess that i'd need the rubber seal and the S1 glass?
I'm going to be cutting perspex windows anyway so could i get away with using the s2 glass as a template then trim it on the outside edge to fit?
Any help much apprciated
You will need the 2 fittings at the front end.
the popperunit with fixings.
the windowrubber.
and if you are using perspex windows you could better use the s1 windows as a template.
as those have already the hole in it for the popper.
I don't know for sure if these windows are a bit bigger...
But that will somebody else tell you..
the windowrubber.
cheers, pretty much what i though. I'd rather not waste money buying the glass just to use as a template but if its the only realistic way of doing it properly i'll just go for it.
Well I don't know for sure if the s1 window is very different.
maybe some one can look for you if the size is the same as a normal s2 window and you can pick the holes your self after you know where they are at a s1 window.
some one kind enough to take the measurement up?
155lee
Sep 6, 2016 11:10 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
