KE-Jetronic Metering Unit - Wire!
Old May 3, 2008 | 07:35 AM
Jucks's Avatar
Jucks
Default KE-Jetronic Metering Unit - Wire!
HELP.. I managed to get hold of a new metering unit for the S2 RST, before i fit her i just want to clarify one thing... The black box on the right of it, i think its the pressure actuator... The plug has broken and i had to put 2 spade connectors on them, I just want to know which way around they go... If someone can have a look to see which colour is on the left and which colour is on the right, from an above view of the unit.. Thanks guys.
Old May 4, 2008 | 11:40 AM
Jucks's Avatar
Jucks
nothing?
Old May 4, 2008 | 02:32 PM
project rs's Avatar
project rs
when you look from above the brown wire is on the right (closest to inner wing) and black/yellow on the left hope that helps
Old May 4, 2008 | 02:35 PM
DazC's Avatar
DazC
I wouldn't have thought it matters as it's only a bimetalic strip which heats up with current flow.
Old May 4, 2008 | 03:52 PM
Jucks's Avatar
Jucks
thanks guys
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
