Mondeo mkI V6 ´95
Old May 1, 2008 | 05:57 AM
JanDK's Avatar
JanDK
Default Mondeo mkI V6 ´95
Hi... (trying copy/paste my problem in here too)
Bought a Mondeo nearly 2 years ago, and it drove "cold"... changed the thermostat, and the car became very hot, not boiling, but very hot (3/4 scale)
I then changed ther waterpump with a new one 8metal impellas)... but the old one was as new! The engine still got hot, and I thought the new thermostat was faulty, and I changed it once again... still the same. the fans kicks in when almost "medium" warm but is can cool it dont to cut the fans again (in other words they run constant) and cant cool down if rise the speed to get more air trough the radiator.
Can it be crappy thermostat (triscan 88 degree) or is it a common problem with these engines???
Can this thermostat be fitted "upside down"???
Radiator is relativly new.
Lost of coolant in the header. Coolant is nice and clean, and the los of water is extremely little.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
