mk 4 power roof problem
hey guys can any1 help with my roof problem i bought the car and it needed hood relays and switch so bought the relays from ford and switch of ebay, fitted them and roof goes down but wont go up, relay makes clicking noise when tryin to put up but pump dont, works manually easy though
thanx cotter
thanx cotter
Sounds like the gear in the pump has ground its teeth off. If the roof is easy to operate, I would check the override on the pump (allows the fluid to pass easily to operate manually) and make sure it is in the right position as well.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
