idle prob
Old Apr 29, 2008 | 09:32 AM
orion88's Avatar
orion88
Default idle prob
hi fellas
got a problem that someone might be able to help with
when the cars cold it misfires like its running on 3 plugs once it warm it runs ok tho but when i hit 4k on the revs its like it hits a flat spot then clears.
a friend reckons its a bent valve but surely it wud do it all the time if this was the case?
any ideas anyone?
Old Apr 29, 2008 | 10:09 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Dont think it's a bent vavle mate, the cam belt would have to have snapped for that to happen and it probably wouldnt run at all!
Could be all sorts of things, plugs, leads, dizzy, timing, poorly setup....... difficult one mate.
If you've not had it on the R/R before might be worth doing it only about £50 for an hour and they tell you for sure what it is.
Old May 6, 2008 | 10:09 AM
orion88's Avatar
orion88
Cool
twas a mixture of the head being blown and the timing
all fixed now tho
cheers for the reply
loving the cab
stuck at work today aswell tis a perfect day to drop the top and go for a spin
Old May 6, 2008 | 02:08 PM
antony215's Avatar
antony215
Escort Rs Turbo
You dont need to snap a belt to bend a valve and it can still run with one bent it will just run like shit.
Old May 6, 2008 | 03:09 PM
orion88's Avatar
orion88
trust me it did
altho turning the boost upto 25psi certainly didnt help
gcfcos
59
Oct 6, 2015 05:04 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
