rear polybushes
Old Apr 27, 2008 | 08:47 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default rear polybushes
are the rear polybuhes easy to fit im not worried about the tie bars its the swing arms
Old Apr 27, 2008 | 09:15 AM
anodised's Avatar
anodised
its getting the old ones out which is the hard bit ur bests off burning the old bush
Old Apr 27, 2008 | 09:18 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
how long for the rear ones you reckon
Old Apr 27, 2008 | 02:31 PM
Turbo-Beal's Avatar
Turbo-Beal
I used a hole saw and battery drill to remove my old bushes from my rear arms and then used a wire wheel to clean out the rest of the rubber. Worked realy well
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
The Enigma
Sep 12, 2015 10:12 PM
truffleshuffle
Sep 10, 2015 09:35 PM
cossirob
Sep 3, 2015 09:17 PM
