ST help please
Old Apr 26, 2008 | 07:42 PM
redcossie's Avatar
redcossie
Default ST help please
can anyone with a small turbo escort cosworth, pls tell me where their boost gauge sits on tick over? As I think I have a problem with mine, because when its on tick over its sitting at the very bottom of the gauge.
Old Apr 26, 2008 | 11:55 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
isn't going to?? you don't have any boost at tickover afaik..
Old Apr 27, 2008 | 08:30 AM
Mr Brannen's Avatar
Mr Brannen
Yeah I know,why would you want it showing boost on tickover LOL
Old Apr 27, 2008 | 09:46 AM
redcossie's Avatar
redcossie
Did I say it was showing boost on tick over
What I said was, the gauge is sitting on the bump stop at the very bottom, when the car is on tick over!
Old Apr 27, 2008 | 10:44 AM
tore_tj's Avatar
tore_tj
Cossie Paranoia
well you do have a vacuum at tickover I guess.. sombody else answer this haha
Old Apr 27, 2008 | 11:51 AM
ECOS95's Avatar
ECOS95
I'm sure mine does this but I can't tell for sure til tomorrow when I drive it, does it move once you pull away ? If it does I doubt you have a problem.
Old Apr 27, 2008 | 01:36 PM
redcossie's Avatar
redcossie
it does move when i drive,but it seems as if its trying
to pass the bump stop on the bottom of the gauge when
on tick over,i though that on tick over the gauge use to
sit about half way between bottom and zero on the gauge,
just looks as if the needle is going to bend,,
Old Apr 27, 2008 | 01:53 PM
ECOS95's Avatar
ECOS95
Mine goes down to -0.6 bar but I can't remember if it goes to the bump stop on tickover.
Old Apr 27, 2008 | 02:09 PM
redcossie's Avatar
redcossie
ok mate thanks,
can anyone else help me clear this up
Old Apr 28, 2008 | 12:03 PM
Dave Henshall's Avatar
Dave Henshall
does it sit at 0 when the engine is stopped? if it does, this is correct.
and it should pull down to nearly the bump stop (depending whether it has any air leaks or a aftermarket dump valve etc) when running at idle or on the overrun.
Old Apr 28, 2008 | 02:44 PM
redcossie's Avatar
redcossie
ok thanks mate
it does sit on 0 when the engine is off,and it sit's on the bump stop
when car is on tick over,it does not have any aftermarket dump valve
and i have just fitted a brand new t28 not a recon,the problem is it seems
to have developed a surge when driving and the needle seems to take
a lot longer to climb up the gauge.......
Old Apr 28, 2008 | 05:03 PM
georgie1's Avatar
georgie1
mine sit at zero when engine has stopped and -0.6 when im ticking over and raise when u boot it hope that helps
Old Apr 28, 2008 | 05:48 PM
redcossie's Avatar
redcossie
ok mate thats a great help.... looks like i do have a problem then
as mine is sitting on the bump stop when ticking over,though that it
looked like it was to low now the fun of trying to find out why..
Old Apr 29, 2008 | 06:51 AM
Aaroncast's Avatar
Aaroncast
mine rests on the'' bump stop'' at tick over then climbs towards boost easily then on to boost then moves like a rev counter does(very freely) -you know you can drive around all day not using the boost!!!!!!!!if you wish-dont push the engine.
ive also got a dumper on mine at the fuel end as against the air intake end.
-no lag -just pulls+pulls+pulls (AS IT SHOULD)
