pectel monitor people
just got my monitor fitted with a new plug and pc data download plug by ryan (car looms uk) cheers mate
all seems to be working fine apart from when you go to page 8 for download data logging it says
DATA CORRUPT - MEMORY BATTERY FLAT
so how do i rectify this? where is the battery as i dont see 1 or is it under that board? i didnt want to pull it apart too much for fear of fcuking it up lol
it is version 6.50e................ memory 128k
an internal pic
also i have full throttle angle 85 degrees but 2 degress when completely off throttle? is this correct as i thought it would be 0 degrees
And lastly what pc software etc do i neeed to actually download and view the data logged recordings
thanks
marc
an internal pic
thanks
marc
Throttle angle is probably O.K. 0.0 Volt is 0 degrees. But the Tps is not going to 0.0 Volt (that would trigger an alarm) but somewhere around 0.1 to 0.2 Volt.
Same applies to Wot. 5.0 Volts is 90 degrees but the Tps is going to about 4.75 Volt.
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
